Siek tiek techniniu duomenu apie calibra:
http://www.nuvision.ndo.co.uk/calibraspecs.htm
Del visa ko nukopinu teksta ir i cia:
Engines
2.0i 8v Cat
1998cc
1990-1992
115PS (85KW) @5200rpm 125.4Lb. ft (170Nm) @2600rpm 4-cylinder overhead camshaft and 8 valves alloy cylinder head, hydraulic tappets and electric cooling fan. Bosch Motronic M1.5 engine management system. Computer controlled fuel injection and ignition with electronic spark timing. Lambda senor and 3way catalytic converter. Compression ratio 9.2:1 (95-Activated charcoal evaporation control canister) Unleaded Petrol only
2.0i 16v Cat
1998cc
1990-1992
150PS (110KW) @6000rpm 144.6Lb. ft(196Nm) @4800rpm 4-cylinder, double overhead camshafts and 16 valve alloy head, hydraulic tappets, electric cooling fan and thermostatically controlled engine oil cooler. Bosch Motronic M2.5 engine management system. Computer controlled ignition and sequential fuel injection with knock control and air mass metering. Lambda sensor and 3 way catalytic converter. Compression ratio 10.5:1 Unleaded Petrol only
2.0i 16v Cat
1998cc
1992-1995
150PS (110KW) @6000rpm 144.6Lb. ft(196Nm) @4800rpm 4-cylinder, double overhead camshafts and 16 valve alloy head, hydraulic tappets, electric cooling fan and thermostatically controlled engine oil cooler. Bosch Motronic M2.8 engine management system. DIS ignition system with dual spark control. Sequential port fuel injection with knock control dual spray fuel injectors valves and hot film air mass metering. Activated charcoal evaporation control canister. Lambda sensor and 3 way catalytic converter. Compression ratio 10.5:1 Unleaded Petrol only
2.0i Turbo
1998cc
1992-
204PS (150KW) @5600rpm 206.5Lb. ft(280Nm) @2400rpm 4-cylinder, double overhead camshafts and 16 valve alloy head, hydraulic tappets, electric cooling fan and thermostatically controlled engine oil cooler. Integral water cooled turbocharger with intercooler. Motronic M2.7 engine management system. Sequential port fuel injection with knock control and hot wire mass metering. Activated charcoal evaporation control canister. Lambda sensor and 2-way closed loop metallic monolith converter. Compression ratio 9.0:1 Unleaded Petrol only
2.5i 24v Cat
2498cc (Ecotec-V6)
1993-
170PS (125KW) @6000rpm 167.4Lb. ft(227Nm) @4200rpm V6-unit with 4 valves per cylinder actuated by two overhead camshafts per bank. Motronic M2.8 engine management system with direct ignition. Twin-jet sequential port fuel injection with hot film air mass metering and knock control. Oil/water heat exchanger. Activated charcoal evaporation control canister. Lambda sensor and 3-way closed loop catalytic converter. Compression ratio 10.8:1 Unleaded Petrol only
2.0i 16v Cat
1998cc (Ecotec 16v)
1995-
136PS (100KW) @????rpm 138.7Lb. ft @????rpm Unleaded Petrol only
Transmissions
Manual Clutch
diameter Gear ratios
1st 2nd 3rd 4th 5th 6th Rev. Final drive ratios
2.0 8v
5 speed (CR) 8.5in 3.55:1 2.16:1 1.48:1 1.13:1 0.89:1 - 3.33:1 3.55:1
2.0 16v
5 speed (CR) 9.0in 3.55:1 2.16:1 1.48:1 1.13:1 0.89:1 - 3.33:1 3.55:1
2.0 16v 4x4
5 speed (CR) 9.0in 3.55:1 2.16:1 1.48:1 1.13:1 0.89:1 - 3.33:1 3.72:1(F)
3.70:1(R)
2.0 16v Ecotec
5 speed (CR) 9.0in - - - - - - - -
2.0 Turbo
6 speed (CR) 9.0in 3.57:1 2.16:1 1.45:1 1.10:1 0.89:1 0.74:1 3.23:1 3.72:1(F)
3.70:1(R)
2.5i V6 Ecotec
5 speed 9.0in 3.38:1 1.76:1 1.12:1 0.89:1 0.77:1 - 3.17:1 3.82:1
Automatic
2.0i 8v N/A 3.67:1 2.10:1 1.39:1 1.00:1 - - 4.02:1 2.40:1
2.5i V6 Ecotec N/A 3.67:1 2.10:1 1.39:1 1.00:1 - - 4.02:1 2.81:1
Performance
Model & year Maximum
speed (MPH)* Acceleration
0-60 mph (secs)* Speed (mph)
per 1000 rpm Kerbweight(kg) 1/4 mile time
2.0 8v
5 speed (CR) (90-95) 127 10.0 (0-62mph) 16.7 (4th) 21.2 (5th) 1194 17.5 secs
2.0 8v
5 speed (CR) (95- ) 127 10.0 (0-62mph) 17.4 (4th) 22.1 (5th) 1230 -
2.0 8v
4 speed Automatic 124 12.0 (0-62mph) N/A 1229 (90 model)
1260 (95 model) -
2.0 16v
5 speed (CR) (90-95) 139 7.5 17.4 (4th) 22.1 (5th) 1219 16.4 secs
2.0 16v
5 speed (CR) (95 ) 139 7.5 17.4 (4th) 22.1 (5th) 1260 -
2.0 16v 4x4
5 speed (CR) (90-92) 134 9.5 (0-62mph) 16.4 (4th) 20.9 (5th) 1304 -
2.0 16v (95 Ecotec)
5 speed (CR) - - - - -
2.0 Turbo 4x4
6 speed (CR) (95-) 152 6.4 17.0 (4th) 21.0 (5th) 25.3 (6th) 1390 14.6
2.5i V6 24v
5 speed (95-) 147 7.3 20.6 (4th) 23.8 (5th) 1340 15.6
2.5i V6 24v
4 speed Automatic (95-) 145 8.3 N/A 1360 -
* Manufacture's Figures
Body
Aerodynamic drag coefficients
2.0i 8v : CD 0.26
2.0i 16v/2.0i 16v 4x4/V6/Turbo 4x4 : CD 0.29
All steel 3 door body with extensive anti-corrosion protectionSafety crumple zones,front and rear. Rigid passenger safety cell. Recessed windscreen wipers. Flush fitting front and rear screens. Concealed front and rear towing eyes. Burst-proof door locks. Tail gate assist struts. Polypropylene front bumper and rear bumper capable of with standing minor impacts of up to 2.5mph.
Suspension
Front. Independent Macpherson struts with coil springs and dampers cartridge (gas pressure on 16v & 16v 4x4). anti-roll bar. Negative scrub and anti-drive geometry
Rear. Independent with semi trailing arms. Progressive rate miniblock springs and Telescopic dampers (gas pressure on 16v & 16v 4x4). Anti roll bar.
Brakes
Dual circuit, diagonally split system with direct action servo.
Front : 10.1in dia ventilated disc brakes with floating calipers. (8v / 16v)
Front : 11.2in dia ventilated disc brakes with floating calipers. (V6 / Turbo)
Rear : 10.2in dia disc brakes with fixed calipers (8v / 16v)
Rear : 10.6in dia disc brakes with fixed calipers (16v 4x4 / V6 / Turbo)
All models : Electronic anti-locking braking system (ABS). Asbestos-free friction material. Hand brake-on and low brake fluid warning lights. Plastic coated brake pipes. Hand brake mechanical, acting on rear wheels.
Steering
Power assisted rack and pinion. Energy absorbing steering column with mesh section, telescopic lower spindle and tear-off support. (Tilt able steering column 1990-1994 models only)
Turning circle 2.0i 8v : 10.15 m (33.3ft) 2.0 16v : 10.65m (34.9 ft). Turns lock to lock 3.3 (1990 models)
Turning circle 10.6m (34.8 ft). Turns lock to lock 2.9 (all 1995 models)
Electrics
12volt negative earth system.
70 amp alternator. 100 amp alternator with optional air conditioning
44Ah maintenance-free battery. / later models 55Ah maintenance-free battery.
Fuel Capacity
14.0 imp gallons (63 litres)
Insurance
8v group 13
16v group 14
V6 group 17
Turbo group 17
